I have a 02 tahoe i put a kenwood dd in and now trying to hook up the amp and sub have two new 30 amp fuses in amp and have ground on metal! every time i hook power wire to the battery it pops the fuses and i have checked over all the wires made sure there were no cuts its brand new wiring kit... i popped the top off the amp and checked the board it looks good!
SOURCE: Blowing the amp fuses
do you have speakers connected as well? do you have a volt meter
make sure you are getting + from both are you sure the remote is not a 5 volt line?
SOURCE: i did what you suggested..
Take it to a car audio shop that has test bench and ask them to check it for you.
SOURCE: amp has power but sub doesnt work
You say the amp has power so you mean the green l.e.d. comes on correct? If so and you don't get any juice to your sub, check your RCAs make sure they're hooked up correctly. If they are check the wires to your sub, make sure they're making good contact, if its a binding post connection to the sub it can look connected but not be i've had it happen to me before. If the l.e.d. is red, you either blew a fuse on your amp, or your sub is blown, but if you get a green l.e.d. on the amp don't worry about those. If everything checks out and you still don't get power, take your setup to a professional and have him personally look it over for you....... hope you get your bass bangin!!!
i am getting 12 volts at the remote terminal when the remote from the cd player is not even conected to the amp!
