After a while the picture on my toshiba 17WLT56B flat panel tv goes off. If I turn the tv off and on again it won't come on and the power led flashes red
Hi sir,, there are only three things to check which causes these problems...
first check whether the cathode ray tube is ok or not second whether the fuse is damaged third is the colour wheel,,, if these are not defnility the circuit problem,,,diodes capacitors
Had the same issue with a 58" Toshiba TV. After getting jerked around by customer support, they replaced it with a new one. If it is under warranty, contact Toshiba to get a tech dispatched.
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing.
The Voltages should be written next to the sockets & plugs on the Power Board.
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. [email protected]
no power
