GE TPX24 BRBJ side-by-side drips water from door dispenser
Dispenser operates properly but water drips from dispenser outlet when not in use. Where is the valve that controls operation of the water dispenser? Does this need replacement, repair or cleaning?
Did you just recently change your water filter? you need to flush 3 gallons of water out of it when changing the filter. if there is air in the line it'll drip constantly. If your ice door isnt closing all the way and properly sealing that also could be a source of water dripping. do you have a low of "Snowy" frost inside your freezer door at the ice dispenser shute?
You will need to replace the water valve. It is located in the back rear of refrigerator. If it is leaking by then you will see drip. Before you replace valve make sure the water pressure of water supply is proper. The valves will not seal properly without proper pressure.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
Your water inlet valve on the back where the
water supply comes in is probably leaking. disconnect the water line coming out
of it and see if you have a slow drip. Try the dispenser to see if it's just
drips after use. You
have two points where you can check the dispenser water. At the rear where the
water supply comes in is the water inlet valve. If you disconnect the dispenser
water line and then see if the water comes out when you try the dispenser. You
should hear the valve work when you try the dispenser. If you don’t hear it
there is a dispenser actuator switch problem.If you do hear it but water
doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of
the freezer door and try again.If it's normal here it may be frozen in the
door. If this is the case open the door till it thaws. A blanket over the
opening will prevent thawing of all the food.
i had the same issue twice. 2 suggestions 1) Remove the front grill at the bottom and you will see a plastic water line. Inspect it to see if it is leaking. Turn on the water dispenser when you are looking at the line. 2) pull out the refrigerator and remove the lower panel. Follow the plastic water lines to a solenoid valve and inspect the lines when you activate the water dispenser. water may leak from where the lines go into the solenoid value. if may be a simple fix like cutting the ends off the lines and reinserting into the solenoid valve.
Hi, it sounds like you have an inlet valve going bad. It is not sealing tight enough to stop the water pressure. Part # WR57X10032and is located below the refrigerator in the back. If you remove the tube that goes to the dispenser, you can probably see the water dripping from the valve. Please let me know if this helps you. Let me know if I can assist you further.
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Ordered part # WR57X10019, valve assembly. Will install when it arrives
