Rural area in Southern California KCBS-TV CBS 43 Los Angeles 24.88 mi 298.04 degrees RCA ANT751 antenna Panasonic 32" Flat screen TC32LX20 Antenna is on the roof set at 298 degrees When I do a channel scan the only channel that comes in is 6 which is a Mexican channel and its not that clear. Is there an adjustment on the TV I am missing ? I go to menu, Program Channel, set it to TV and do a auto program. Any suggestions? Thanks
SOURCE: Can't pick up all the signals
I always tell people to carefuly read their instruction manual and consult the product tech support before determing that there is actualy a fault with their unit.
If sounds like the tuner module or the controler board for the tuner may be failing, or there is a power supply distribution fault to the tuner section and or its controler. This has to be service by the manufacture.
One of the criteria I recommend when people buy an expensive appliance or TV is to make sure that there is local authorized service. I also recommend an extended warrany for expensive items. The warranty is like insurance. You may or may not need to collect!
Jerry G.
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler,
I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: Basic broadcast channel plan vs. indoor digital antenna
Hi masaki h,
I am happy to help.
It is almost impossible to tell how well an antenna will work . It depends on atmospheric conditions, distance to the broadcast tower and a number of other factors.
The new flat antennas look nice and should work fine but your best course of action is to buy from a store with a liberal return policy. Places like Walmart will take the antenna back for any reason as long as you have an reciept.
Somtimes a cheap set of rabbit ears work as well as a expensive amplfied antenna.
I say give it a try and if not acceptable return it and try another one.
I have provided a link to a site that will explain more about DTV and antennas.
Please rate this solution and please keep in mind that any rating except FixYa is a negative to my rank here
Thanks Lone99star
SOURCE: Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
SOURCE: Can't program digital channels only has analog option
If your TV does not have a digital tuner, you'll need a digital converter box.
After the digital switch in June, did you have channels then? If so just do a rescan.
