2005 Chevrolet Equinox Logo
Anonymous Posted on Feb 23, 2009
2005 chevy equinox, washer motor working but no fluid is coming out to either front or back
  • julieheater Mar 20, 2009
    i have the same problem with my 2006. it sounds likeit wants to work
Anonymous
Level 2:
  • Expert 25 Answers
  • Posted on Sep 16, 2009
Anonymous
Expert
Level 2:
Answers
25
Questions
0
Helped
61236
Points
173
Hiya
it uses one washer fluid tank in the engine area that provide fluid for front/rear windows.
you could pull the rubber hose off at the bottom as a first check to ensure the washer pump does function to shoot fluid from the washer fluid tank.
if there's fluid still in it, look inside to ensure no forgein/gunk object is plugging the bottom inside.
check the washer fluid tank in the engine area and see if the rubber hose is still connected to it?
also check for no kinked or pinched point along the hose...just follow the hose to see it's not compressed flat which could be the cause of restricted washer fluid movement.
5 Related Answers
Anonymous
  • 205 Answers
  • Posted on Mar 22, 2009
SOURCE: Rear windshield washer motor works, but no fluid comes out
Rear washer may have it's own reservoir . Can you hear a pump humming when you activate the washer? Look in the under flooor compartment
Anonymous
  • 5158 Answers
  • Posted on Jan 29, 2009
SOURCE: How do I add power steering fluid to 2005 chevy equinox?
first and it's sort of obvious... make sure the motor is off.... look for a cap at the front of the motor where the fan belt is... may even be labled power steering ... you add the fluid there
Robert
Anonymous
  • 79 Answers
SOURCE: 2005 chevy equinox temp gauge showing hot fan
check the coolant temp sensor
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Aug 24, 2009
SOURCE: I have a 2005 Chevy Equinox and my windshield
u will need to pull the washer fluid tank out and check to see if the tank motor that pumps the fluid is getting 12 volts when the washer switch is pushed, if it is the pump will need to be replaced, if it isn't then the washer switch is defective, this switch is part of the turn signal switch.
john h
  • 29494 Answers
  • Posted on Nov 01, 2009
SOURCE: i have a 2005 chevy equinox i replace the front
check the connections on the abs, behind the rotor by strut is the connection for the abs if the connector is loose or not properly affixed to the clip it sets off the abs trouble code or low speed saftey usually activates at slow speed under 5 miles an hour the connector and clip are part of the abs circuit--also recheck ur brake pads for binding and brake fluid level --if u get a trouble code have vehicle scanned some auo stores such as auto zone / advanced auto scan for free this will tell u which sensor or unit is causing problem
How do you add antifreeze in a 2005 chevy equinox
In the surge tank on the drivers side of the engine compartment aft of the windshield washer fluid reservoir.
The line that separates the top and bottom halves of the tank, inside the tank is the cold fill line and should be just covered when the engine is cold. Never open this tank while hot, scalding fluid will shoot out and burn you severely!
Need to pull radator out of 2005 equinox with 3.4 liter motor
Some of the new Chevrolet needs to be taken apart. The front end will come apart fairly easy, but you may want to call a Chevy dealer or get a book from an auto parts store for $11.00
How to fill power steering on a 2005 chevy equinox suv
In your owners manual
If you have to add any fluids to any
vehicle system you have leaks to repair
No fluids are consummed
Has to be next to the pump on front of motor
1helpful
2answers
Does the chevy equinox 2005 use steering wheel fluid... If so, where is it located in the engine?
The 2005 Equinox utilizes electric assist power steering. There is no hydraulic steering pump or reservoir.
1helpful
Equinox has wet floors on both sides in front.....windshield wiper fluid has been filled twice, and just becomes empty. 2008 chevy equinox, do not know what is wrong or what is leaking
1) don't these cars come with a 5 year 50,000 mile warranty? if so take it to a dealer
2) if not under warranty I would replace the washer fluid lines coming from the washer fluid reservoir. something has become disconnected and fluid is not getting to the nozzles. you may need a repair manual to show you how to get to them.
4helpful
2answers
I have a 2005 Chevy Equinox and my windshield washer fluid does not work. The reservoir is full and the wipers wipe, but no fluid comes out. nothing is leaking under the car either. what else can i check...
2006 Chevrolet Equinox Washer Fluid all over back floorboard
you have a hole in your hose line going to the windshield
3helpful
Robert
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
