Merge two excel sheets with same columns with sum.
Please assist me to develop a tool to merge two excel sheets with same columns. If desciption is same then it should not be duplicated. But the value must be summed up.
Please help
Suresh
Sounds like your issue can be solved readily with a pivot table.
If you give the columns of names a title like "NAME" and the number columns a name like "VALUE". All other columns should contain a unique name.
Then select the entire table, including the labels at the top ensuring that the range extends entirely over the column you need to sum the values of.
In Excel 2013, choose the INSERT menu and select the PIVOT TABLE command.
Insert the Pivot table into a new worksheet.
A new sheet will open with a strange-looking control panel on the right of the window.
Make sure that the box for NAME and VALUE (only) are checked
You will notice that Excel assumes that you want the SUM of the values for each NAME summed. The results are in the leftmost area of the worksheet.
If this works for you, please vote my answer as "helpful".
Merging Columns In Excel
Now that we've clarified what merging columns actually means, we can explore how to do it. The first step is to perform the merge for the first cells. Let's go back to our first example and suppose that we are merging column A that contains first names with column B that contains second names. We'll put the merged columns into column C. To merge cell A1 with cell B1 we woul type the following into cell C1:=A1&" "&B1
More information is required so I will only assume you are using Excel as a database. Excel is a spread sheet program used by accountants or for mathematical formulas and ledgers. Access is the Database program, however, Excel has functions which is faster to sort and work with address, phone number, zip codes. I will confess, I use Excel as Database because it is quick and easy. I do not know what version of Excel you are using so I will describe it from Office 2007.From Excel make sure you have headers above each column i.e. First Name in Cell A1 Last Name in Cell B1 Address in Cell C1 ect.
Make sure your data is correct and case sensitive as you would like it. If you want zip+4 select the Colum and right click to format the cells using special and select Zip or Zip+4.
It is easiest to use Microsoft Word for the next step rather than format the cells, add page breaks, and customize the print size.
Save your document as an Excel document where you can find it to import it into Word.
Open word and select Mailings then Start Mail Merge and Step by Step Mail Merge.
Select Envelope and next. Select envelope options to change envelope size, font and print options.
Click on Next Select recipients.
Click on browse under select an existing list.
Select the Excel file with your address information.
From the Select Table check the First row of data contains column headers.
Click on the OK buton.
Arrange your envelope then Preview it and your good to go.
If you have an older version of word selects Tools and click on Mail Merge.
Select Get Data.
Pull down Excel for document type.
Select entire Spread Sheet.
Layout your document and complete the merge.
On old versions of word it may not recognize the Excel file. If this happens open the Excel file and save it as a Database File (.dbf) and it should work.
I hope this helps since I did not have enough information from your question.
You need to go into format cells and then merge them together and you should be just fine. Highlight the cells that you wish to merge and then right click and then click on format cells and then merge cells together.
This can be caused by the worksheet being protected. Check on the Review tab in the Changes group and see if the Protect Sheet or Unprotect Sheet icon is visible. If the Unprotect sheet icon is visible, then the sheet is protected and that would cause the merge cells icon to be inactive.
If the column names and orders are same across files, then you can directly use the MS Excel's import data function, this will do your job.
Alternatively, if you want to do it manually, import each file in separate excel worksheet using data import wizard or simple copy paste of data (in latter case you have to use Text-to-Col feature of excel), and then manually append all figures (copy-paste in one go) to any external excel sheet.
Then finally, export/save as that external sheet to any filename of your choice.
Try this:
1. Find the copy of the workbook on which you will merge the changes. In Excel, go to "File > Open" and find the file.
3. Click "Tools > Compare" and "Merge Workbooks."
4. Look for the files you want to merge and add them into the current file.
5. Click “OK” to merge the files. This is your master copy of this workbook.
6. Save the file.
at first select the 1st page data and select data-subtotal from the upper menu list.
then enter the formula as =sum(1stpageSubTotal,2ndpageSubTotal,3rdpageSubTotal) then Press Enter.
If not solved pls get me that data as to reference.
