Zenith C27V36 27" TV Logo
Posted on Feb 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I scan for channels with my RCA converter box
I have a RCA converter box and set it up a few months ago, today our local channel converted to a digital signal and now I need to scan for channels again. I've misplaced my instructions and cannot figure out how to do it???????????????????????
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 373 Answers
  • Posted on Feb 18, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
373
Questions
Helped
164644
Points
984
The remote should have a scan button on it.
then the screen go thru it process and it should say done
How can i get local channels on my rca tru flat tv BD20TF10
The RCA BD20TF10 was manufactured before digital tuners (ATSC) were required. It only has an analog (NTSC) tuner so you will need a digital to analog converter box to watch most local channels. (These were the boxes available with the discount coupon as the ATSC broadcast transmitters were enabled.) Depending on the converter box model, use either the composite video input or use the RF antenna connection. If you use the RF output from the converter, you will need to set the TV to channel 3 or 4 (set the switch on the box to match). Then follow the directions for searching for channels with the converter box.
You may be able to find a low power analog station still broadcasting. However, you'd need to be close to the transmitter or have an antenna that is rated for a long-range signals. (Usually this will need to be an outdoor antenna with few obstructions between the transmitter and the antenna.) To scan for any available NTSC channels, make sure that the TV is set to TV mode. Then press Menu. Use the Up/Down arrows to highlight Channels and press OK. Select Auto Channel Search and press OK. You may need to confirm this step by highlighting the Start Search option and pressing OK. This will also let you add the appropriate channel for watching the signal from the converter box with the RF cable. The manual for this TV is available from Sears Parts Direct here: http://www.searspartsdirect.com/partsdirect/user-manuals/BD20TF10-Rca-Parts-Television-Parts-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0312126.pdf .
I hope this helps. I'm not sure if the Menu feature is available from the front panel buttons. You may need a remote with a matching code to do the channel scan.
Good Afternoon, I have no cable where i live now, but i have a analog converter box, how do i install it to my tv to get local channels?
you install the cable wire into the box or antena into the box then the cable or rca cables into the tv. set the tv input to the right input (usually channel 2 or 3 for a cable) or input one for the rca cables then you need to hit the scan option on your converter box to scan for the channels and the tv to scan for the channels. please let me know if this works
2helpful
2answers
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
2helpful
4answers
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
1helpful
Won't recieve digital channels
I have the same type of TV and as soon as i figure out why it also, will not convert from analog to digital ,I can hook up to converter box get all kind of clear channels I am quickly finding out These Sets Are either minor problems or very major problems. They have over 32 different SSB tuner boards,and they all look alike but are not, hookups and connectors are not the same.
Unresponsive RCA Digital Converter
You may need to change your antenna for digital reception. Make sure the outlet you are using for the converter box has power to it.if that does not solve it you may have defective box.
biigg53566
1helpful
Cannot get tv to synchronzie with hd converter box
YOU NEED TO GET INTO THE MENU AND EITHER AUTOPROGRAM THE SET WITH THE CONVERTER BOX ON OR BUY A REMOTE AND DIRECT ACCESS CHANNEL 3.
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
