HP iPAQ RX3115 Pocket PC Logo
Posted on Feb 17, 2009
Ipaq rx-3115 stops at align screet after reset
Unit stops at align screen after a reset and will not cycle past that screen after reset.  I have upgraded ROM with no luck.  Unit does connect through active sync.
  • Anonymous May 11, 2010
    Does the screen respond to your stylus during the aligning step. I only ask this because the boot-up process won't continue until you participate in framing the screening.
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jul 09, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
4248
Points
9
Sounds like u need a replacement LCD
Easily found on ebay
Replacement screens usually come with instructions.
Please note u will need a hollow t8 or t9 tool to open the ipaq case.
My ipaq h5555 wont let me get past the align screen feature. Can any one help?
do a reset ( like full rese) or if you dont want to leave it off for a few hours and turn it back on AND DONT GO TO THAT SCREEN
Ipaq rx-3115 stops at align screen after reset
This happened to me and i got so mad that i broke the screen. But that was a good idea because then i got a new screen and now it works fine. Just get another screen and it should work fine. or you can just get the digitizer part and swap out your LCD parts.
I can't make my IPAQ pass the align screen
Replaced LCD touch screen in Australia.  Cost $95.00 AUS Thanks for Fixya help you where really great.
INSTALLING
how much did you pay for this pda? did you buy it recently? Is it brand new or are you the second owner?
3answers
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
2answers
Ipaq rx3115 doesnt turn on!
I am guessing that you have made sure that it is fully charged. If it is, since you have only had it a week I would try a hard reset. I don't know if the 3115 has them but check to make sure that any battery door lock switches are locked.
IPaq keeps moving appointment times
the ipaq automatically adjusts for daylight savings but the PC does not. On your PC double click on clock, click on Time Zone tab and then on that screen you will see the box that needs to be checked. also check that both PC and IPAQ are set to same time-zones.
Charging
If it's completely dead USB probably can't do it at all. There's a voltage threshhold, and USB only puts out about half the voltage needed to get over it. USB usually won't manage when thenbattery's below 30%. Try connecting the iPaq directly to the AC adapter.
Rx3115 locking up
To execute a hard boot on the iPAQ rx3115, the manual says to "while pressing the two outside buttons on front of iPAQ, press the recessed reset button on bottom." Hope it Helps... Wirzan
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
