20 Most Recent HP iPAQ HX2110 Pocket PC Questions & Answers
go to contacts/ phone book options /you can delete one at a time or try manage contacts choosing multiple contacts to delete
HP iPAQ HX2110... | Answered on Jun 21, 2010
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
HP iPAQ HX2110... | Answered on Jul 24, 2009
does it matter if usb charging is enabled? just looked through the menus and it has a slow/fast charge option etc?
HP iPAQ HX2110... | Answered on Mar 29, 2009
I think the battery may be fully dead, test it with a meter, and if it wont charge through the device, take it out, find a charger with a similar output and jam the wires into the correct terminals on the battery (+to+) it'll get red hot but you need only do it once. (I've done it to my psp battery and it worked fine) careful though, don't leave it on overnight or unattended.
HP iPAQ HX2110... | Answered on Dec 21, 2008
nstall new ROM from this page ==== http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/download/22776.htm l and all will be OK !!!
HP iPAQ HX2110... | Answered on Sep 11, 2005
In activesync under Tools/Add REmove programs you can check the box and click "ok" that will install the program. For the most part it's best to do it one program at a time. Obviously your PDA should be cradled or this. Most programs will re-install fine this way. Some programs though do require you to re-install from the installtion program directly since active sync doesn't pick up some important parts of the program. The two programs I have that require the special install are: CLC Journal since it has an outlook component and sets up a sync for the Outlook Journal. The Stowaway Keyboard driver since it had to ask me what language (the new driver doesn't do this...) The other 30 odd programs I have install straight from active sync.
there are many,many options. I have the IPAQ Navigation System with my 4700 which I like.
HP iPAQ HX2110... | Answered on Sep 08, 2005
It might be checking for emails, or trying to sync - check these two options. Or it could be reminders not going away.
HP iPAQ HX2110... | Answered on Sep 07, 2005
What model HP iPAQ?
HP iPAQ... | Answered on Oct 28, 2013
HP iPAQ HX2110 Pocket PC Logo
26 questions posted
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iPAQ HP
  • iPAQ HP
Most Popular Question
ipaq hx 2110 will not go past align
  • Computers & Internet
