Question about AEG Washing Machines
Spin Basket Spins Along with Agitatdor in GE Profile Washing Mach
There is a GE Profile Washing Machine that recently has problem with the Spin Basket Spinning in circles at the same speed along with the Agitator, this seems to effectively canceling out the washing effectiveness of the GE Washing Machine.
Even when the machine is fully powered off and not in use the Spin Basket can now be easily spun in full 360 circles by hand; it used to be locked in position like the wheel of a car when in park and could not be spun around ..
What could cause this and is there an easy fix ?
machine fills with water and then does nothing..... it is a general electric top loader washing machine
  • 3 Answers
It is like that because you can **** a ****
Posted on Feb 16, 2009
GE WBHV5200J3WW shakes during spin cycle with load in the machine
you might need a new Motor Asm Kit part number WH20X10028
the pic below is Motor Asm Kit that you might need okay
Jan 29, 2013 | Washing Machines
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
Washer doesn`t spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 04, 2010 | GE Profile WPRE6100G Top Load Washer
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
Basket won't spin
Unplug machine for two minutes, plug back in and open and close lid 7 times slowly. This should reset electronic motor.
Jun 05, 2009 | GE WBSR3140DW Top Load Washer
Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Jun 02, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
if washer is newer version remove front panel and ck if has a gearcase it's probably bad if it has what ge calls a mode shifter it's probably bad it has a coil with connection to motor bd..look on bd for flashing green 4 flashes means open mode shifter coil
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
GE 1996 top loader agitation but good spin cycle
check the motor, the timer,the water level indicator in side the machine on the basket it will have a tube with a little box attached to it. It may be clogged or malfunctioning.
Apr 27, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
138 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
