I'm using the FInepix S3 Pro (firmware version 2.18) with the Hyper Utility HS V3 to control the camera via the "Studio Utility" program. It was working fine until recently and now everytime I click to control the camera the program crashes. I have tried reinstalling the program to no avail and even done a windows restore point (i'm using windows Vista 32bit) which also didn't work.... any ideas?
What did you do or what changes did you make to your computer since all operated fine? Bad things just do not happen - you must have done something that is now responsible for the issue. Can you repair your Vista installation - your OS may be at issue. If you have other computer with Vista try installing there to see if it works. Maybe something is now wrong with the camera - it happens.
SOURCE: softwear for finepix camera
The A202 is a European model and they do not have updates for Vista that I could find. You can however find the updater program for the FinePix software that includes Vista. http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportSoftwareContent.jsp?dbid=864214&prodcat=644675&sscucatid=664260
SOURCE: s3 pro and studio flash
I have Fuji S3 pro and One body locked up during a reception and ERR displayed. 1st i turn off and on . it is work ok. 2nd time it happen again and still show ERR on dispayed. no way to reset. my camera out of warranty. estimate cost for repair 400$ per manifacture.
SOURCE: Successfully installing Hyper-Utility2 on my Mac
Hi Paula,
Something that happens with Macs is the file permissions get messed up from installer programs. This problem usually can be corrected by running the disk tools program. It is usually located in your Applications folder in the Utilities sub folder.
You did not specify with version of OSX your Powerbook Pro is running. Make sure you have all the updates from Apple for your OS. You might also need to get an update from Fuji for the Hyper-Utility2 software. That can be found here: Fuji
Lastly, iPhoto is compatible for quick downloads from your camera
SOURCE: Fuji FinePix vs. Vista. Worked a few weeks ago, not now
It's very hard to troubleshoot software problems online, and it likely is a software issue. But why put up with the headaches of bad software in the first place? Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
SOURCE: Finepix s8000fd - drivers/Vista
You can getdrivers from:
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/d-slr-long-zoom/finepix-s8000/Support
