Master
- Posted on Jan 13, 2011
Re: Sir, I Have JXD 656 recently I connected it to my
WARNING : This procedure can render your device dead, so do not try if your player is working fine.
- The most important step of the whole process is to correctly
identify your device CONTROL CHIP and CPU, using wrong firmware or
flashing tool may cause damage to your device, unscrew and open your
device and write down all chip id's and motherboard numbers you see, you
can also try the EasyChips - firmware identification utility but it did not worked for me.
You will now need to download the correct firmware and flashing
utility for your device, visit sites below and search for your control
chip and cpu to download the firmware and flashing utility, you can also
post on user-forums to get help identifying the firmware :
In my case the chipset was Sunplus AJ262-V7 and the utility needed to flash it was FRM Pro.
Once identified you need to connect your device to computer
via USB in camera mode (Press A + OK button and plugin USB cord on
player), for Windows to identify this mode you will need camera drivers
you need to point Windows Found New Hardware Wizard to Driver
folder downloaded with the FRM Pro utility above, this will install the
first camera driver, for correct identification by flashing utility you
need to install a second camera driver - open Windows Hardware Manager
and install unidentified camera device drivers by pointing the driver
wizard to Driver folder used earlier.
Now install and launch FSM Pro flashing utility the new firmware.
