aperently it has to do with converting the analogue signal to digital or the other way around..rca is the cable type..the signal is what you are having issues with..you may need a converter..it may also require going into the setup menu of the tv and make it recognize the signal..
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
3D effect caused by failing convergence chips on the internal control board. You will need professional intervention to repair or replace this board or the chips. Often this is in association with other parts that need attention and is not a DIY.
This is a convergence output IC problem. convergence board (main Board) would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
LG rearprojection Television
What type of monitor are you using?
