SOURCE: Blue power light is on, but no picture is displayed
Strange that you should post this question to this forum! If the set was purchased in jan 2006, you have a Manufacturer's warranty! USE IT!
SOURCE: TV BLACK SCREEN WITH THE POWER ON.
i have a phillips flatscreen plasma sound works but no picture.What can i do to fix it. is ther a chance that it could be something simple? or is this going to cost me a small fortune to fix.
SOURCE: tv won't turn on or respond
the power supply is faulty, check the following for lekages
power transistor
rectifier diodes
fusable resistors
also griver transistors
It needs repair.
If the line is vertical, then something is damaged on its horizontal circuit section on the mainboard.
If the line is horizontal, the vertical circuit section is damaged.
have it repaired to a qualified service center or person!
avoid switching it to avoid further damage on other parts!
SOURCE: TV will not respond shows black screen only, & red light come on.
I have the same problem, did you have any luck?
