I am trying to conect this TV with a new Directv Box, but I am getting no sound or picture. I know where to connection, just no sure if I should be using Monlink or antenna 1 or what
im trying to hook up my ps3 to my 62525 to the monolink hdmi and all i get is a blue screen im trying to hook up my ps3 to my 62525 to the monolink hdmi and all i get is a blue screen
You can't post conmments that contain an email address.
Monlink is the Connection I used with my Directv. All you need to use is the HDMI cords. Are you trying to also connect to stereo system or something other than a straight HDMI connection from Directv Box to WD-62525
My guess is that your DirecTV box is outputting in a format your television does not recognize. Some models of the DirecTV box have a button on the front of the box for formats (480,720,1080) and you may be able to press that button until the picture comes in clear.
If there is no button:
1: Try an alternative connection tyoe to the TV from the box (if available, like RCA or coax), then switch the TV to that new input. If you get a clear picture with that connection, then in the settings menu for the receiver there should be format settings where you can select which formats to output. one of the selected formats chosen would be causing the problem. Change or remove one of the formats. (. I.e. if 720 is selected, deselect it.) After that switch back to the original connection and input to test.
or 2: The DirecTV box could be connected to a different TV and in the settings menu for the receiver there should be format settings where you can select which formats to output.
Another unlikely possibility is that the HDMI cable or slot on the TV itself is bad. Try switching the cable or try a different slot in the TV if available.
d12-100 box does not have an hdmi port what it does have is a problem the signal level coming out of the box is to high install a 4 way splitter between the box and the tv line out of the box to the in of the splitter any port out of the splitter to the tv the problem you are having is called ghosting
The problem is generally the cables, period. If there is a condition whereby the cable was bent, kinked, overheated, or the end damaged in any way, this problem can exist. Many times when a cable is attached to the device, it is cross-threaded or left loose. If the contact is not 100%, you can experience this condition. I suggest that you obtain NEW cables and connect them tightly and firmly in place. This should eliminate the problem, UNLESS the male connection on the device/s have been compromised.
Try different ports. Use and HDMI cable and see if it is doing on it. If you are using a HDMI cable now hook the connection up with the component cables and see if it is doing the same thing. If it is clear on one of the other ports you have a port on your mainboard that is bad.
I have comcast and get buzzing from the box when everything is off. Do you have the option of unplugging it and having the t.v. on by itself or will the provider have to come reprogram it. If not, disconnect box to rule out t.v. before t.v. warranty is out.
CC is a feature of the TV. All TVs are different in features and the Vizio is limited on its features due to cost. To eliminate the directv receiver connected to Vizio TV just swap with the receiver connected to Sharp TV and see if CC is displayed.
I just got through explaining this to someone else - the HDCP encryption system that Philips uses is not future-proof - you will continue to have this problem as long as you use an HDMI connection with a Philips TV. My advice, which you can take or leave, is to use Component (Red, Green and Blue) cables. you won't get 1080p, but you will get 1080i, which is pretty close.
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
With the RGB you have to run seperate audio ,I think you have ran the seperate cables for the sound but they are in the wrong place.try changing the RW from the DVR to the TV and you should get sound from them.The unfortunate truth about the HDMI is that the HDMI format has a problem effectivly communicating between components.I am a Directv certified High Definition technition and %50 of the TV's that I connect the HDMI to will not receive the signal.One trick that I have found that works is to make sure you have a picture on the RGB then connect the HDMI.Once you have these connected ,turn your TV off and unplug the power cord from the DVR for 30 sec then plug the DVR in and wait 5 minutes for it to power up then turn your TV on and switch to your HDMI input.This method sometimes works to "Jumpstart" the HDMI input on the TV .There is no guarantee that this will work but is sounds like for now this is your only option,GOOD LUCK.
It won't work as the DAv can only output to HDMI by bringing singal into the HDMI input.
why wouldn't you send it directly to the TV and Audio to the DAV? I sounds like you don't have an HD box anyway (otherwise why would you use an analogue S-video cable vs component or HDMI). Unless there is a distance issue then go to the TV.
