Philips SWV6813-17 HDMI 3-Way Switcher Logo
Posted on Jan 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HDMI picture is saturated in the wrong color
This only happens with the connection from the DirecTV box. PS3 and bluray have the correct colors but when I switch it to the DirecTV box the colors get completely screwed up. This has happened before but unplugging and replugging the cables has resulted in correcting it but not this time. Any ideas?
  • Tony Parsons
    Tony Parsons Jan 14, 2018
    This isn't really anything to do with Cameras, is it ?
Zelio Picanso
Level 2:
  • Expert 59 Answers
  • Posted on Jan 14, 2018
Zelio Picanso
Expert
Level 2:
Answers
59
Questions
0
Helped
14992
Points
152
Here is what you can try.
Plug the PS3 cable into the HDMI port directrv is on.
If ps3 looks good,then you ruled out an issue with the HDMI port.
Next swap directtv HDMI cables with the ps3 HDMI cable.
See if it works fine or not using the ps3 HDMI cable.
If all works fine,then you know its the HDMI cable itself.
If the directtv still does not look right,than it is a setting the the video output on the direction tv box.
I would start with that first,see what you find out.
Good luck
Z
I’m happy to help further over the phone at https://www.6ya.com/expert/zelio_00a80ed57645ccbf
Dayton Computer
Level 3:
Master:
  • Master 669 Answers
Dayton Computer
Master
Level 3:
Master:
Answers
669
Questions
0
Helped
199973
Points
2079
The problem is generally the cables, period. If there is a condition whereby the cable was bent, kinked, overheated, or the end damaged in any way, this problem can exist. Many times when a cable is attached to the device, it is cross-threaded or left loose. If the contact is not 100%, you can experience this condition. I suggest that you obtain NEW cables and connect them tightly and firmly in place. This should eliminate the problem, UNLESS the male connection on the device/s have been compromised.
5 Related Answers
Anonymous
  • Posted on Jan 17, 2009
SOURCE: DVD playback color is very red
plug red yellow and white cords in all the way
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jan 18, 2009
SOURCE: no picture/intermitten picture
I just got through explaining this to someone else - the HDCP encryption system that Philips uses is not future-proof - you will continue to have this problem as long as you use an HDMI connection with a Philips TV. My advice, which you can take or leave, is to use Component (Red, Green and Blue) cables. you won't get 1080p, but you will get 1080i, which is pretty close.
-Tha Mp3 Doctor
Anonymous
  • Posted on Feb 13, 2010
SOURCE: My philips lcd tv is switching inputs/channels by
tv key pad section complind
Anonymous
  • Posted on Feb 20, 2011
SOURCE: Magnavox Bluray Player with the HDMI Cable will not produce sound
no sound on my blue ray player
daevilb
Anders Bergwall
  • 103 Answers
  • Posted on May 03, 2011
SOURCE: when connected via HDMI, get picture filled with
You can ofter setup HDMI on your devices in different modes, for example my old tv had options that i could change RGB and other settings for hdmi. try looking in the settings of the DVD-player and see if you have hdmi options
My colored tv has a black and white picture what is wrong
Check the picture settings, and color system setting. If color system setting is nor correct, this might happen. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
How do i FIX THE COLOR PROBLEMS I HAVE WHILE WATCHING DIRECT TV? Dynex DX-L42-10A 42 in. LCD TV
My guess is that your DirecTV box is outputting in a format your television does not recognize. Some models of the DirecTV box have a button on the front of the box for formats (480,720,1080) and you may be able to press that button until the picture comes in clear.
If there is no button:
1: Try an alternative connection tyoe to the TV from the box (if available, like RCA or coax), then switch the TV to that new input. If you get a clear picture with that connection, then in the settings menu for the receiver there should be format settings where you can select which formats to output. one of the selected formats chosen would be causing the problem. Change or remove one of the formats. (. I.e. if 720 is selected, deselect it.) After that switch back to the original connection and input to test.
or 2: The DirecTV box could be connected to a different TV and in the settings menu for the receiver there should be format settings where you can select which formats to output.
Another unlikely possibility is that the HDMI cable or slot on the TV itself is bad. Try switching the cable or try a different slot in the TV if available.
I have a 37" Olevia and the HDMI plug in creates a off color picture, kinda what 3D looks like. I have tired different HDMI cables and still getting the same picture. It does happen when I go to connect...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Just set up a 26' Vizio model Vl26m; used setup wizard; we have directv and I have a black and white picture but no color...
it sounds like you have your video in the wrong input you should be using either componant 3 color cable red blur green plugged into the correct inputs or HDMI if your sat box has it let me know please
2helpful
Bose cinemate no sound
Yes it will work coming straight off the dirctv box. What kind of tv do u have that doesnt have an audio out. I have had to actually use rca splitters to get sound from bluray and cable box because the new samsung led tvs only have optical out. Dont forget the unit not being used must be off or u will have 2 source sounds at one time playing.
No picture/intermitten picture
-Tha Mp3 Doctor
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
I have a 27" color flat screen tv by Samsung which I bought from Best Buy in Lakeland, FL 4 yrs ago never had a problem til now. I had a power outage in my home but the tv wasn't on nor was the...
Try to use your directv box with a different A/V connection to the TV and see what happens?
EX. If you have a basic directv box using coaxial cable connection,try to use RCA(yellow,red/white) cable to a RCA input behind the tv.
solutiondoct
When The HDMI cables are connected, I use Directv, I have just recently started to have the picture come on and then start flickering and various color bars pop up on screen, then the screen will go black...
It is possible that the HDMI cable is defective. Did you try another cable?
It is also possible that the HDMI port on the TV is failing.
This can be determined by the process of elimination.
Jerry G.
2answers
Major problems with PS3 and viewing Bluray movies
did you uncheek the other options when choseing 1080p or it might be your receiver because you have to set that to make the picture quality as much as the ps3
Top Philips Cameras Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Philips Camera Expert? Answer questions, earn points and help others
