There are inputs on the back of the set. If your tv is Sony 51ws510 then it is capable of HD, but you have to have component or DVI cables to connect the tv to the HD device (HD cable box or DVD player).
<br>
<br>
On your set the component inputs on the back of the tv are video5 and video6 in the middle located in a vertical line (red, green, blue rca video connections with red and white rca audio connections).
<br>
<br>
You also have a DVI input toward at the top of the input panel (white connector with red and white rca audio connectors).
HDMI is just one the lastest inputs for HD. Look on the back of your set for Componet input as this is also an HD input. The colors to look for are RED< GREEN<BLUE connectors on the back labeled componet.Also with using componet inputs you will need seperate audio cables for the input. you can use the red and white from your rca cables and omit the yellow. HDMI is only one of the types of input but is the best as of now for 1080P picture quality, But Componet will give you 1080i HD Quailty.
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
Ok so the sound is fine on all of the other sources, The component is running from the cable box to the amp, and you can see it. just take the audio Red/Whit RCA out of the cable box, and input it to Cable/TV or whatever its labled, Red White, RCA.
If you want surround, then you will have to go Coaxial((single orange RCA) or TOS out of the cable box to the Digital input on the AMP. When you use this instead of Red White RCA, your amp will automatically switch between the different types of surround depending on what the source calls for or is encoded in.
You may have to get into the amps menu and change that amps input to Digital/Coax/TOS for the surround sound.
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
