Mitsubishi WD52527 52 in. HDTV Television
Problems with Mitsubishi WD52527 52 in. HDTV Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Mitsubishi WD52527 52 in. HDTV...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Mitsubishi WD52527 52 in. HDTV Television RSS Feed
View More Results for Mitsubishi WD52527 52 in. HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WD52527 52 in. HDTV Television RSS Feed
Answer
mire me parece un demo de la lampara y no se como otra quitarla y remplaze la que tenia por
Answer
I have the mitsubishi WD5257 HDTV. My problem is that the TV is not recognizing any of the devices... (More)
Answer
Mitsubishi WD-52327..has a lot of vibration,tries three times to work then shuts off I have a new... (More)
Answer
I also have the green light flashing for about 30 seconds and than goes off. i tried to count the... (More)
Answer
replaced lamp and wiped the optical lens with tissue as it had pink hues in picture. was told this... (More)
Answer
my Mitsubish wd 52527 has a blue screen and you can hear the tv just not see a picture. Repair man... (More)
Answer
Lamp LED is steady red. I obtained and replaced Bulb with Philips 915P028010. Turn set on,... (More)
Find a Manual
Mitsubishi WD52527 52 in. HDTV Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and... written by willtab
Updated! Convergence Problems & Solutions - With example photos
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV... written by Ecollier2012
How To Fix A Convergence Problem
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen... written by Ecollier2012
Distorted Video - Convergence Problems - 3D Looking
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the... written by Ecollier2012
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for WD52527 52 in. HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Rate and Review the Mitsubishi WD52527 52 in. HDTV Television
Write a review:
Rate this product:
Would you recommend the WD52527 52 in. HDTV Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Mitsubishi WD52527 52 in. HDTV Television
Key Features
Screen Size
52 inch
Digital TV Standard
HDTV - HDTV receiver is integrated. · HDTV
Projector Technology
LCD
Display Resolution
1280 x 720 pixels
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Broadcast Format Displayed
Remote Control
Remote Control
Multibrand
Illuminated Remote
Illuminated
Image Quality
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Type
Stereo
Sound Leveler
With Audio Leveler
Technical Features
Picture in Picture
With PIP
Connectors
Rear Input Connectors
Component x 2 · S-Video x 2 · Composite x 2 · RF x 2 · Audio (RCA) x 6 · HDMI x 2 · FireWire x 2 · G - Link
Rear Output Connectors
Composite x 1 · Audio (RCA) x 2 · CableCARD
Screen Text
Closed Caption on Mute
Without Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Dimensions
Depth
17.8 in.
Height
33.9 in.
Width
49.6 in.
Weight
110 lb.
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
