If the motor doesnt run during the spin cycle and the tub stays full of water. You need to replace the lid switch. This is very common problem. The part should be around 35 bucks. Easy fix.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
does it wash and do you hear the motor running in drain or spin
