brushes not turning roundbrushes not turning round
AnonymousMar 22, 2014
how do i take it out to clean i have not got the booklet to help say how...it needs to be cleaned as motor cuts out as it gets hothow do i take it out to clean i have not got the booklet to help say how...it needs to be cleaned as motor cuts out as it gets hot
the suction is not very good and the machine has cut out. have lost my instructions to find out what i can dothe suction is not very good and the machine has cut out. have lost my instructions to find out what i can do
You can't post conmments that contain an email address.
first, if it has a hose check for being plugged, you may have to take the vacuum apart further till you reach the fan on motor which may have hair,lint,etc wrapped around it which can cause low suction. Checking for Blockages in Your Vax Upright Vacuum Cleaner
press helpful button
Sounds like a clog in the plastic that the hoses are connected to. Take bottom off so you can get in with a wire with a small hook and run all the way to the bag you might have to work from the bag opening down too. You should find a big wad hiding some ware in the housing this is an all to common problem with most brands of this type of vacuum.
mine too.. I got local place to do a deep clean (sic) of all the filters but its made little difference. Hardly does a room before cutting out and then you have to wait an hour for it to cool down. am veryy disapointed
Unfortunately there is no permanent solution.It is a terrible vacuum cleaner and im getting rid of mine today. I have been maintaining it for 6 months cleaning filters , swapping filters, swapping carbon brushes all to no avail.Dump it. it would'nt **** the air out of a balloon.
