You will need standard HDMI only if your laptop have HDMI port. I think hp 6510b not include HDMI port. It has VGA and SVEDIO Output. Your toshiba TV have many PC INPUT Ports such as S-Vedio, D-sub , VGA like old Desktop PC connection with Projector). So buy VGA cable or S-vedio Cable, then you can connect.
Click here to download the user manual to your Philips TV, and check its specification page. You can see compactable video formats that the TV can accept. Check it with your computers video out format.
Normally all one has to do is use a 15pin VGA lead to connect the laptop to the TV socket, select PC on the TV and that should be that. There may be problems if your laptop in a MAC and if the resolutions do not match.
I have never used that programme but expect it uses the sound card as an interface. If it does, the manual will tell you, you will need a Phono lead with 3.5mm jack plug on one end. Hope that helps.
If you are using a LCD/TFT tv it will have HDMI and VGA inputs.
You only need a simple vga lead but this only transfers video not sound.
You can get a usb to hdmi lead, you can also plug in audio leads from your headphone socket and this will transfer video and audio.
Why do you want to get to the lens? Do you think it`s dirty, if so, try buying a laser lens cleaner, It will be a lot simpler and safer than stripping the set down.
In answer to your original question, Yes, You do have to strip the set and then you`ve got to strip the DVD player because it is buried inside a metal can. Then you`ve got to clean the lens, put it all back together, Praying that the fault has been cured. Please buy a cleaner first, I used to repair these kinds of sets and they are a nightmare, and I`ve been down this road before and it really is an awkward job especially when you put it all back together and then find that the CD door isn`t properly located or a lead isn`t connecting properly or a lead broke as you removed it. I`ve been there, I`ve got the T shirt. Ian
the toshiba convergence repair kit is available at the following link for your model. It contains the parts and cd with detailed instructions http://www.tvrepairworld.com/
Hi there It depends on the TV really, if the TV has a VGA port on the back then what you will need is a male to male VGA cable, you will not get any audio however so you will need R/L phone to mini stereo jack lead also.
