SOURCE: rca tv 27V513T
i've kind a seen this problem before i dont beleive a univesal remote will help because the problem i fond is you can not get a menu to pull up with universal. you may try to hit the power button and volume together or try to push two button at ince can't remember right of the top of my head what the are but it will help you get to factory program side i beleive then you may need to program
SOURCE: RCA Model 27V513T FPA Lock On
hey i have the same problem only i don't have a remote and i locked my tv out of my own stupidity. its model no. is 27V512T if you're any good with chips mabye you figure out a way to reset the tv.
SOURCE: rca tv 27v513t fpa lock
yesterday i was watching tv but suddenly it turned off and after that i was trying to turn it on but i wasn't.......but today it turned on , infact i was trying to turn it on.........i wanted to know what is the problem so pressed on botton and it said "FPA ON " after 10 min.again it turned off..............i don't know what should i do...........can you please solve my problem......i will be so nice of you.
thank you
SOURCE: The FPA lock is on and I don not have the original
You can buy a replecement remote control for around $20. Here is a link to one:
http://www.ecrater.com/p/5577807/rca-260605-remote-control-1186
1.
Hold down MENU
on the remote and VOLUME DOWN on the TV it's self at the same time for at least
4 seconds. The set won't say so, but the lock will be unlocked
2.
Hold down the 0
on the remote and the VOLUME DOWN buttons on the TV its self at the same time
for at least 4 seconds. The set won't say so, but the lock will be unlocked
3.
Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds.
4.
Hold down GO
BACK on the remote and MENU on the front of the TV at the same time for at
least 4 seconds.
5.
Hold down EJECT
on the front of the TV and the MENU button on the remote at the same time for
at least 4 seconds.
Depending on the model,
one of the methods should unlock the V-chip. Now, if desired, you can change
the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS,
or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
