20 Most Recent
Apex Digital GT2011S 20" TV Questions & Answers
Omni tv
with the original omni remove....press the button with a square and has a + sign on it for a couple of seconds
Tv will not come on
Sounds like a short issue. More than likely a shorted horizontal output transistor. First all fuses need to be checked. If good, check the HOT. If the HOT is shorted and a common part you'll be ok. Apex does not support it's products. In most cases they are impossible to repair due to unavailability of parts. Anything beyond the HOT will probably not be obtainable. If you are going to look at this unit remember safety. Good luck.
Locked tv
The Digital Channels are Blocked and Some of the Annalog Channels are Blocked that you can't access some channels and how do you unblock the channels by getting rid of the Code for Parental control?How Do you get rid of the Parental Code to acess all Channels .
Apex tv
hold down display key on remote for 30 seconds will reset
I need to know how to change modes without controller when I'm using a dvd
Without a remote controller, you may have limited options to change modes on your Apex digital TV. However, you may be able to change the mode by using the buttons on the TV itself.
Here are some general steps you can try:
- Turn on your TV and make sure your DVD player is connected to it.
- Look for the "Menu" button on the TV and press it.
- Navigate through the menu options using the arrow buttons on the TV until you find "Input" or "Source."
- Press the "Enter" button to select the input/source option.
- Use the arrow buttons to select the input/source that corresponds to your DVD player.
- Press the "Enter" button to confirm the selection.
- Press the "Menu" button to exit the menu.
Note that the specific steps may vary depending on the model of your Apex TV. You may also consult the user manual for your TV for more information on changing modes without a remote controller.
