Apex Digital GB5108 51 in. Rear Projection EDTV-Ready Television
Problems with Apex Digital GB5108 51 in. Rear Projection...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Apex Digital GB5108 51 in. Rear...
Troubleshooting and Support
Solved Problems for Apex Digital GB5108 51 in. Rear Projection EDTV-Ready Television RSS Feed
View More Results for Apex Digital GB5108 51 in. Rear Projection EDTV-Ready Television
Questions and Unsolved Support Problems
Unsolved Problems for Apex Digital GB5108 51 in. Rear Projection EDTV-Ready Television RSS Feed
Answer
the t.v have a yellow light , but it doesnt turn on, with remote or with the t.v. botton
Answer
i have a apex gb5108 51 in pro tv if i turn it off and try to put it back on it comes back with a... (More)
Answer
on my Apex GB5108 tv the picture is compressed in the center of the screen. I can see it run through... (More)
Answer
Hi, I have a colorful ribbon in the middle of my apex tv. You can still see half of the picture.... (More)
Answer
I have a Apex tv. GB5108 51 inch screen. It comes on. Indicated by green light. Then, turns itself... (More)
Answer
i have an apex 51 inch the screen does not turn on nor does the sound . it stopped while watching Is... (More)
Find a Manual
Apex Digital GB5108 51 in. Rear Projection EDTV-Ready Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Apex Digital GB5108 51 in. Rear Projection...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Apex Digital GB5108 51 in. Rear Projection EDTV-Ready...
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Apex Digital GB5108 51 in. Rear Projection EDTV-Ready Television
Key Features
Screen Size
51 inch
Display Format
480p (EDTV)
Digital TV Standard
EDTV-Ready
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC
Remote Control
Remote Control
Universal
Image Quality
Comb Filter
With VSM
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Variable / Fixed
Audio Type
Stereo
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
RF x 1 · S-Video x 1 · Component x 2 · Composite x 2 · Audio (RCA) x 3
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output Connectors
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
Without Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Dimensions
Depth
22 in.
Height
56 in.
Width
43 in.
Weight
155 lb.
Warranty
Overall Warranty
1 Year
Tube Warranty
2 Years
Apex Digital Contact Information
Main support number866-427-3946
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
