TV won't turn on, the light comes on and turns red like it will kick on, then flashes back to...
(More)
TV won't turn on, the light comes on and turns red like it will kick on, then flashes back to yellow, then red. Keeps doing it then shuts off. How do I fix this?
my samsung tantus tvs color is all messed up..their are colored lines and the picture is jumping up...
(More)
my samsung tantus tvs color is all messed up..their are colored lines and the picture is jumping up and down
Apex GB43HD10 wont turn on you can hear a low tic sound from the power supply pcb.. no led lid on...
(More)
Apex GB43HD10 wont turn on you can hear a low tic sound from the power supply pcb.. no led lid on the front panel..and no relay tic.
I have a apex digital 43" gb4308. All I get when turned on is a rainbow of color through the...
(More)
I have a apex digital 43" gb4308. All I get when turned on is a rainbow of color through the middle of my screen?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
