SOURCE: what buttons do i press on the remote to remove fpa lock on a rca tv model 27v513t
Most RCA TV
sets use a four digit code to control the v-chip. The code reset procedure is
different depending on the model. Try each method until you find one that
works: 1.
Hold down MENU
on the remote and VOLUME DOWN on the TV it's self at the same time for at least
4 seconds. The set won't say so, but the lock will be unlocked 2.
Hold down the 0
on the remote and the VOLUME DOWN buttons on the TV its self at the same time
for at least 4 seconds. The set won't say so, but the lock will be unlocked 3.
Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds. 4.
Hold down GO
BACK on the remote and MENU on the front of the TV at the same time for at
least 4 seconds. 5.
Hold down EJECT
on the front of the TV and the MENU button on the remote at the same time for
at least 4 seconds.
Depending on the model,
one of the methods should unlock the V-chip. Now, if desired, you can change
the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS,
or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
SOURCE: rca tv 27V513T
i've kind a seen this problem before i dont beleive a univesal remote will help because the problem i fond is you can not get a menu to pull up with universal. you may try to hit the power button and volume together or try to push two button at ince can't remember right of the top of my head what the are but it will help you get to factory program side i beleive then you may need to program
SOURCE: tv turns it self on and off, it won't stay on
Maybe the eeprom are corrupted and need to be changed
1.
Hold down MENU
2.
Hold down the 0
3.
Hold down the
4.
Hold down GO
least 4 seconds.
5.
Hold down EJECT
at least 4 seconds.
