Image cannot be displayed message is flashed on the display for some files in the cannon dslr eos rebel t3i camera
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
SOURCE: poor image displayed on cscreen after shot taken
I have an s60 and it sounds like I had this exact problem. Whenever I took a photo, the entire picture was covered with white horizontal lines. The actual image files were striped the same way.
I found this on the Canon USA site:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=223&modelid=10149
Because it was a hardware issue, they sent me a shipping label, I sent in the camera, they fixed it, and sent it back. All free of charge.
Good luck; I hope your camera is repairable.
SOURCE: Cannon PowerShot A85
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
SOURCE: Canon SD1000 display is black while the camera in shot mode
After some inspecting of the camera it seen the issue lies with the lens, not the camera itself so don't go banging the camera up or you might damage some other part and the camera will be broken for real. Inside the lens is a closer which block the internal system from capturing image. The closer look just like the one you see before turning on your camera but it's smaller and it's inside the lens way in the far back. Look carefully and you'll see it - you will see the closer if your screen is black while in capture mode otherwise you will see a nice round glass (the internal lens for capturing image/video).
Think of if like this, imagine an eyeball with its eyelid close. That's what happened when the screen is black while in capturing mode.
HOW TO FIX IT: In order to fix the black screen while in capture mode and cost as little damage to your camera as possible, simply turn on the camera in either picture or video mode and look inside your lens, there should be a closer in the far back end. Gently hit the lens a few times until you don't see the closer no more and only a round glass and your camera should begins capturing image and video again.
Good luck to you all. And remember don't use anger to force your camera to works or you will regret it.
If you need further help, contact me via email y a j y e e (at) h o t m a i l (dot) com
Yee Yang
Canon PowerShot SD1000
SOURCE: display window is blank and not showing image being shot
Go into setup and enable LIVE VIEW, however, you cannot use LIVE VIEW in Full Auto mode.
SOURCE: Cannon EOS Rebel XS shows busy display stopped working
Just got a brand new camera. Played around with it a few nights to learn all the parts and buttons. Went to a concert tonite. While waiting for the show I took many test shots to see how the camera would work under these contiditions. Used a 75 to 300 Cannon lens. I had just got the settings about right when the show started. All of a sudden the display went dark and "busy" flashed in the view finder. But it would not take any more pictures. Taking the battery out and removing the sd card did not help. The auto focus and flash still worked but nothing else.
This camera is going back to the store if I can't get some help. PLEASE............. vj
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files. I suggest that you transfer the images from the Camera to the computer and check if it works. After transferring the images, get the Memory formatted from the Camera and start capturing new images. The edited images will not get displayed in the Camera again. Please try not to edit the images in the Computer without transferring it.
Thanks.
KenSolutions
FixYa
