General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
A
Anonymous Posted on Jan 12, 2013
F230 code on my whirlpool accubake oven came up. What does this mean?
The model number and serial number on my Whirlpool gold electric stove have faded out on the sticker of my stove. Please help me in finding the model and serial number of the stove in the attached image.
I notice is it also in French, so I am guessing you are Canadian? Greetings from Mississauga! Its a guess... but..
YGY397LXUS Whirlpool Range Canada - Sale! Best Price ...
www.canadianappliance.ca > Ranges > Whirlpool
Whirlpool Gold YGY397LXUS Slide In Electric Range, 30in, 4.5 cu.ft, with AccuBake Temperature Management System, Self-Cleaning Oven, Delay Bake, ... This AccuBake system uses a sensor to monitor the oven temperature; it will then turn ...
Whirlpool GBD307PDS09 Built In Oven - Electric Timer - Stove ...
www.appliancetimers.ca > appliance
I have a Whirlpool Gold double oven and someone came to house and told me it ... black panel on whirlpool accubake system self cleaning oven gives double ...
Somewhere hidden in the stove, should be the engineers spec sheet. It should be one of these images
https://www.google.ca/search?q=%22whirlpool+gold%22+%22self+cleaning+oven%22+%22Accubake+system%22
Here is your error code
There may be a problem with the Oven Temperature Sensor, the Warming Drawer Sensor (if so equipped), or the associated wiring. Power unit down by turning off the circuit breaker(s) for one (1) minute. ... Monitor the oven for one (1) minute to ensure the error code does not display again.
Dec 14, 2019
F3 E2 - Electric Range - Product Help ' Whirlpool
https://producthelp.whirlpool.com/Cooking/Wall_Ovens_and_Ranges/Electric_Ranges/Error_Codes/Error_Code%2C_Fault_Code_or_Message_-_Oven_Control/Starts_with_F3/F3_E2_-_Electric_Range#:~:text=There%20may%20be%20a%20problem,for%20one%20(1)%20minute.&text=Monitor%20the%20oven%20for%20one,code%20does%20not%20display%20again.
Why does my stove say f230?
It would help to know what make and model of stove it is.
The first step is to unplug the stove from the wall for 30 seconds or more, then plug it back in
Troubleshooting steps
https://www.hunker.com/13416829/how-to-fix-a-ge-oven-showing-error-f2
https://removeandreplace.com/2016/09/06/whirlpool-oven-error-codes-what-to-check-how-to-clear/
GE/Whirlpool/Kitchenaid/Kenmore share many of the same parts, here is a list of error codes.
https://www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Oct 30, 2019 • Ovens
Whirlpool accubake oven display has gone so dim that I must turn lights off in kitchen to be able to adjust the oven. Is there a replacement bulb or panel or known fix? Bob & Janet
MMMMmmmm see this:
eBay: $44.99 (OR BEST OFFER!) NEW
391847690458
$10 shipping
Here is a USED panel, eBay ~ same price:
Whirlpool AccuBake Oven Control Panel 8304270 8304243 eBay
Whirlpool Accubake Oven Control Panel 8304270 8304243 NEW
Anthony
(Say Thank You!)
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
I have whirlpool accubake model wle 3430 almost 10 years old and have a code E1 F1 and oven is not working ! 1 e
The F1-E1 error code means the control board has detected a problem within the control itself and the control board needs to be replaced
When ordering the control please note it may also be called the,CLOCK,EOC or Electronic Oven Control in addation to the control board..any of those names it will be the same part.
GENE
1helpful
What does f5 mean on a whirlpool accubake oven?
It either means that the door lock is bad or there is a stuck key on the touch pad.
1helpful
2helpful
2answers
Oven not working on wirlpool accubake system
I have a Whirlpool Accubake System stove / oven. About 50 p% of the time I go to push the "Bake" and "Start" button, it goes to "Cal" or "EO -F2-" what ever that is. It won't let me clear it . Needless to say I am not happy with the fact that when I go to bake something, the oven doesn't work!!! Please help!
Top General Electric Hardware & Accessories Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
