Troubleshooting & Support
Problems & Solutions
I want to turn off the clock on the stove
i want to turn off the clock on my whirlpool stove
oven beeps and displays F2 or F3?
Hello there: this error code is telling you that the oven temperature sensor is going haywire and needs to e replaced Here is the 2 error...
timer keeps going off
push in timmer knob turn till its at 12 o clock if it does not shut off then the timmer is bad ..you can dissconnect timmer from the back...
WE have a GE Stove top Range. The burners...
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts...
Cannot reset clock on my electric stove after a...
Unplug the stove for 10 minutes, then plug it back in. This should resolve your problem...
Hotpoint self cleaning oven won't heat
maybe a bad connection with the heating element. Check to make sure bottom element is pluged in all the way. May need to be replaced if...
oven doesn't light, ignite
I assume it a gas operated oven. In the past I have gotten the gas company out to reajust our stove at no cost. If it is a gas unit you need...
How to set clock on GE range
press and hold the timer key for 5-10 seconds see if it flash;s if so use the arrows for hour and min, comment back with all the...
Oven buzzer won't stop. F-1 is flashing.
http://www.applianceaid.com/fault_codes.html#f1test
Oven Lock stuck open before start of self-cleaning...
Sounds like you bent the door where the lock is. You might have to replace the door.
Replacing oven burner element, the lower element,...
> (I think it is 50 watts or volts??) Most electric ranges are supplied with 220 volts - this is, especially at 60 Hz,...
Timer with red switch on side. The switch is
Open following link for instructions how to set timer by experimenting with features:http://waterheatertimer.org/How-to-set-timers.html
lower element in oven will not come on I replaced
You need a multimeter to do some fault-finding. Also, check for a (usually hidden) square ceramic fuse mounted inside the thermal insulation...
knob turned off but strater keeps clicking
timer my still be on or it could be stuck
how come the broiler is working and the oven is
When you select oven setting do the oven element and the broiler come on at the same time? If they do and the oven is not working the oven...
See all General Electric Stove/Oven/Range Chrome Timer Solutions
Unsolved Problems
oven wont heat up
when i turn on the temperature dial the light does not turn on nor does the oven heat up
how do you replace the heating element in a...
doesn't heat enough.
ge 6 inch electric burner
ge model number jbp26wv2ww I need a new electric burner
ge profile electric stove loc error
LOC in digital display; unit locked. How do I reset LOC
my general electric oven reads "hold"
It is an older model and I cannot seem to find the model or serial number on it anywhere. I can turn the oven on but I...
had a power outage at home power back on but oven...
power went out when restore my oven no longer has power range top is fine looking for possible fuse locations
See all General Electric Stove/Oven/Range Chrome Timer Problems
Manuals & Guides
TopDo you have a manual for General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459? - Upload it to FixYa!
Upload a manual for General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
What's your problem?
Fix-O-Meter
19,946
19,946 people have viewed this product
- 293 people asked about this product.
- 51 people found solutions for this product.
- 8 people have added this product.
How to wire...
