General Electric GE 24-Hour Timer, 2-Pin #15004 Logo
Posted on Dec 13, 2009
Setting GE Plug in mechanical timer 24 Hr Model 15119 instructions
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 18, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11937
Points
47
Pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
  • 1 more comment
  • Black Blonde Oct 22, 2010
    Man that was easy enough. Thanks Alot!!!!!!!!!!!!!!!!!!!!!!!
  • Ann O Dec 17, 2010
    The instructions don't say you have to pull them all up first! This was helpful. Thanks!
  • zac thomas
    zac thomas Jun 11, 2014
    Do u leave the lamp switch in the on posistion, does it work with power strips ie can u plug it into the power strip or plug the power strip to the pin timer?
Anonymous
Level 1:
Problem Solver:
  • Posted on Dec 13, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
0
Helped
11937
Points
10
How to program the 24 hour ge mechanical timer plug in
Timer GE15119 should the lamp be on when you plug the timer into the wall outlet ?
It is a very basic mechanical timer. I have 3 of them.
Remove it from the wall.
Pull the tabs up for Off and Push tabs down for On.
Set the Time by turning the dial, time to arrow.
Set the slide switch to Timer On.
Plug in the appliance.
Plug the timer into the wall socket.
Manual and Advertising is here.
GE 15119 Manual - Waterheatertimer.org
http://waterheatertimer.org > pdf > GE15119-Man...
PDF GE 15119 timer manual http://waterheatertimer.org/How-to-set-timers.html http://waterheatertimer.org/GE-timers-and-manuals.html#52012.
GE 15119 Indoor 24-Hour One-Outlet Plug-in Basic Timer ...
https://www.toolboxsupply.com > products > ge-15119...
GE Indoor 24-Hour Mechanical Timer is an easy-to-use basic timer. Ideal for lamps, seasonal lights and portable fans. Turns a lamp on/off at desired times daily, ...
10helpful
I cannot set my GE timer--15119----I have no instructions and have tried many times---I can't believe how difficult this timer is to set----
Here's what I found.
Pull up all of the little pins around the dial.
Push down all pins for the time that you want the light to stay on.
Leave pins up for all time that you want the light to stay off.
Rotate the dial to the current time of day.
Plug timer into wall.
Plug light into timer.
Ensure light is ON.
Gary
7helpful
Setting the GE timer 15119
the GE timer 15119 is a push pin design. The easiest way to start is to ensure all pins are up, then push down the pins that represent the time period you want the appliance ON. For example, if you want a lamp on from 7pm to 10pm, push down the pins between the 7 and 10 on the black portion of the dial. then rotate the dial clockwise until the arrow points to the current time of day. Turn switch to the "timer on" position. Plug the timer into the wall outlet, then plug the lamp or appliance cord into the timer and you're done.
Hope this helps.
26helpful
I have ge model 15119 24 her timer and need help on how to set
GE 15119 timer is a 24-hour plug-in dial-type timer.
Dial rotates as time passes.
Plastic segments located around outer edge of dial control on-off operations.
Each segment represents 30 minutes of 24-hour day.
Timer comes with segments down.
Each segment can be lifted up using small screwdriver under edge of segment.
Segments down, timer is ON.
Segments up, timer is OFF.
So if you want timer to turn on at 7pm and turn off at 11pm, then lift all segments around dial except segments between 7 and 11.
Dial is divided into two parts > day and night.
Nighttime hours are shown by numbers with dark background >> notice small crescent moon where 12 midnight is located.
Daylight hours are shown by numbers with light background, and sun symbol shows at 12 noon
To set current time, so timer knows what time it is right now:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There is override switch located on one side of timer.
Move switch to Timer ON position and timer program will function.
If you want to turn lights ON using override switch, move switch to OUTLET ON.
Last steps:
Turn lamp on.
Plug lamp into timer.
34helpful
I have basic timer # 15417. No instructions came with it and I don't know how to set it..
GE 15417 is electro-mechanical plug-in timer
GE 15417 GE15119 GE15131 are combined in one instruction sheet:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15119-Manual-eng.pdf
1) Rotate dial until current time lines up with stationary black triangle located in center.
2) Segments around outer dial divide 24-hour day into 48 half-hours. Lift segments for times you want lights to be OFF. Segments down for times you want lights ON.
3) Slide-switch on side of timer is manual override. To use timer function, set switch to 'Timer ON'
4) Plug light into timer, plug timer into wall.
5) Maximum load is usually around 500Watts >> check markings on timer for exact load capability.
33helpful
2answers
How do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Top General Electric Hardware & Accessories Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
