20 Most Recent Whirlpool GS475LEKS Gas Kitchen Range Questions & Answers
my oven was converted to LP gas we move overseas.It worked for about a year then all of a sudden the oven stopped working. The burners work perfectly but the oven just keeps clicking after preheat is finished. We replaced the upper electronics board so what could it be now
Whirlpool... | Answered on Dec 21, 2013
F3 - E2 Oven too hot Replace oven temperature sensor
Whirlpool... | Answered on Feb 06, 2013
Hi sauerteig_j,
Whirlpool F2 error code indicates that oven temperature is too high. And to fix this problem:
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. Just have your model # ready when you call.
Hope this helps.
Thank you for using FixYa.
Whirlpool... | Answered on Jun 04, 2011
F2
Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this
2. For SELF CLEAN
temperature
Whirlpool... | Answered on Mar 09, 2011
Sorry to read about your problem, I hope this helps you out.
if you can remove them, soak in hot water and clean, if you can't. clean the holes with toothpick or needle, etc.
take a match and start the burners, you may be able to see which holes are blocked..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Whirlpool... | Answered on Jan 05, 2011
Note for ID purposes only. Component locations differ.
Sometimes bypassing a badly corroded connector will do the trick.
If that puppy is open, or shorted to frame, OR out of spec it is bad
How to check that pesky sensor video:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Whirlpool... | Answered on Dec 19, 2010
Hi
Thanks for using FixYa.
Error F3-E2 in your Whirlpool oven means oven too hot and to resolve this issue you'll have to replace the oven temp. sensor (probe). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Whirlpool... | Answered on Oct 07, 2010
PF stands for power failure...the power went out to your range... you will have to reset and reprogram the range...
heatman101
Whirlpool... | Answered on Mar 31, 2010
e2-f3 meens your oven sensor is bad. if you look in the back wall of the oven you will see a probe a little smaller than a pensil held in by two screws. remove power then the screws and slowley pull the sensor into the oven far enough to unclip the wires. sometimes you have to remove the back to do this then replace the sensor.good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Whirlpool... | Answered on Jan 18, 2010
Does the glow bar get hot? If not you have other problems.The new valve might have a on/off switch, look for a little flip lever to turn it on. Some were shipped in the off position.
Eric
Whirlpool... | Answered on Dec 19, 2009
F-2(Oven temp is to high)
Follow the procedure below:
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Whirlpool... | Answered on Nov 21, 2009
have it calibrated, usually behind the knob when removed,
or more easily remember this and get a little oven thermometer , Theyre better anyways and the stat if not junk will maintain desired setpoint without much variance
Whirlpool... | Answered on Aug 25, 2009
I HAVE A 2 MONTH OLD GAS RANGE AND IT APPEARS ED-F3 AND THE OVEN DOOR IS LOCKED HOW DO I GET IT TO UNLOCK
Whirlpool... | Answered on Feb 23, 2009
If this is electronic ignition, then chances are the burner or ignitor nub has residue on them, preventing the flame detection system from keeping the gas on.
Use warm soapy water and a plastic scrub brush to thoroughly clean the burner cap, burner base, and ignitor nub.
Whirlpool... | Answered on Jan 25, 2009
Whirlpool GS475LEKS Gas Kitchen Range Logo
49 questions posted
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Kitchen Ranges
Most Popular Question
whirlpool gs475lems range oven problems
  • Kitchen Ranges
