Try another outlet in another room(not tv needed) try replacing the power cord, other than tath buy a new n64, there only $15 and the power cord will be about $5
repairpal.com/brake-hydraulic-system-red-warning-light If the brake hydraulic system red warning light comes on and stays on, this indicates... and seems to come on and off depending on whether the vehicle is turning, ... if it is discovered that the light was illuminating due to a low brake fluid level.
Power shuts off during use What color is the power light when the system shuts off? Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged. Or the battery needs to be replaced if it does not hold a charge Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
Follow the procedure below to fix the problem on your ps3,
1.
Turn off Playstation®3. 2. Hold the power button down; the system
will turn on and turn off once again. 3. Once the System has been
shutdown, re-press you finger until you hear 2 consecutive beeps 4.
When you hear the 2 beeps take finger off power button. 5. You will
be prompted to plug in your controller via USB and then hit the PS
button 6. The Recovery menu will pop up.
The current Recovery
Menu supports: • Restart System: Restarts the PLAYSTATION®3 System. •
Restore Default Settings: Reset all system settings back to default. •
Restore File System: Checks for corrupt/missing system files. •
Rebuild Database: Rebuilds the OS for the PLAYSTATION®3. • Restore
PS3 System: Fresh restore; Deletes everything and starts from Scratch. •
System Update: Update the PLAYSTATION®3 System.
The temperature inside the system may be too high. Touch the power button on the system front to stop the flashing and then leave the system turned off until it cools down. After it has cooled down, turn on the system again. PS3 should turn on.
Hello. There are a few causes for this. I will list acouple solutions for you.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine. 2. If option 1 does not work call Sony because the video out chip has blown or come unsoldered.
With the system turned off, disconnect the speaker wires from the amplifier. Turn on the system. If the light stays red, then the amplifier has an internal problem. If the light turns green, then your problem is a blown speaker, or a speaker wiring issue.
