and when i try to take a picture it comes out in coloured blurred linesI turn on the camera..
and it has weird streaky lines across the screen,
You can't post conmments that contain an email address.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
The camera is probably damaged, this also happend to my DMC-TZ5 as well after a few (5-6) years of heavy use but without any visible damage, a repair is most likely more expensive than just buying one of the new lumix cameras which have also improved A LOT, so you wont be disappointed!
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
possible fuse. if the red is curved or bent, if the red is straight try covering tv with blanket so the sensors get a good reading. again if the red is bent, and fuses are good..... bad convergence ic's.... local service center
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
