SOURCE: remote code for Seiki TV 32"
The 4 digit code 0060 worked for me with a comcast remote - light gray remote with dark grey OK button. this was on a Seiki 22' LCD TV. I programmed the TV control on the comcast remote first by using 0000 (remote blinked twice accepting the code) then using 0060 (blinked twice again). This code seems to work. Not sure if the sequence or combination is actually needed.
The "try the Samsung codes" suggestions works. I have a ONN (Seiki) LE-24G90. The first Samsung code on the HDTV list (1019) did the trick on my Telus CISCO ST6400 remote.
SOURCE: why is my seiki 32 tv picture blinking off and on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size
SOURCE: why is my seiki tv picture jumping on and off
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
