I have a Kenmore 90 plus series washer that is not spin drying the cloths. I hear the motor going i think. The water is draining out, but not getting the excess water out of the cloths before they go to the dryer.
The wash cycles are working.
There is a part between the moter and something else and i can turn it by hand when I lay it over on its side.
washer doesn't spin at all..... other functions seem okay???
Check your lid switch...bad lid swich...
you sure this washer washing...you can see it washing,,
ok you have a broken motor coupling,,thats between the gearcase and the motor...no was no spin,,just fill and drain...
how technical are you ,,and the part only a couple of bucks,,its up to you ..part # 285753A motor coupling
ok just go to service matter .oom and pull what you need,,ok servicematters,com
Correct... washes, drains, etc., but doesn't spin?? What do I need to do to repair the problem?
Lid switch works okay, still not spinning??? You can here sound of spin cycle at bottom, but there's no movement.???
wife said was washing, but no spin. I checked spin and doesn't work. I just checked wash cycle.... fills, doesn't agitate(wash), drains okay, and still no spin... now what?
is this something I can repair or replace?
Thank you.....yep; I'm okay to do the job, but do you have a diagram you could send me?? [email protected]
I have a Kenmore elite washer Model #: 23012100. Everything works fine until the spin cycle. Then it starts making this whining sound as if the gears are trying to work but can't. Any suggestions on what the problem could be and if it can be repair "easily"?
SOME TIMES IT SPIN SOME TIME IT DOSENT
ice pic,,,,pick the washer back up ...thats a no no ...now i think i understand,,your washer just doesnt spin ,,but it will wash..correct onthejob
