SOURCE: Aculaser C2600 "clean sensor" message
This is a common characteristic which arises from using improperly remanufactured toner cartridges.
Otherwise it is a bad Epson original one - which is highly unusual!
When the C2600 runs through its calibration it prints strips of each colour on the transfer belt which are sensed for density. You will get a "clean sensor message" if the reading for any of the strips drops below a certain value.
The first thing to do is to depress the clean sensor lever behind the front cover several times . If that doesn't fix it I would advise you to remove each cartridge in turn (go to reset menu and scroll down to change toner) and inspect the toner on the surface of the roller. If there is any form of "sheen" then you'll need to replace the cartridge.
It is possible to adjust the doctor blade if you know what you're doing but be careful as there are shims on each side. Loosening and moving the blade bar towards the roller slightly, refixing and then turning the side cog to rotate the roller can sometimes resolve problem. Not a good idea really unless you're in an emergency.
There are some good remanufactured cartridges and bad ones. If you want to avoid this buy genuine Epson cartridges - I know they're expensive but what does the down time cost!
