Philips 43PP9202 43" Rear Projection Television Logo
Natalie Pod Posted on Jun 21, 2007
Cloudy TV Screen
Hi, I was writing because I just noticed some cloudiness to my screen on my TV and wanted to know if there is a way to fix it, and what the costs typically runs? Any help is greatly appreciated, thanks!
Shane Harrison
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Feb 11, 2013
Shane Harrison
Contributor
Level 1:
New Friend:
Answers
20
Questions
Helped
5880
Points
32
It could be on the inside of the glass as in moisture steam that has dried on there
Anonymous
Level 1:
  • Contributor 41 Answers
  • Posted on Jul 02, 2007
Anonymous
Contributor
Level 1:
Answers
41
Questions
0
Helped
8122
Points
38
If you can remove the front screen, look down into each CRT tube lens, blue, green & red see which ones are cloudy. The cloudy ones need the fluid changed which is a coolant. Shops charge between $75 to $150 a tube to change.
Cloudy screen
It's possible that you have moisture on the inside of your camera, causing the sensor to fog up. It is also possible that you have fog on your lens as well. I have had cloudy images with my Nikon when it fogged up inside. The best thing to do is to make sure it dries out. This usually solves itself so long as you are in a dry location, but if not I would take your camera to a local repair shop to have it looked at and fixed. It really does sound like a moisture issue however. Do NOT dry your camera using heat or anything! If it doesn't dry on it's own, take it to a pro to get it fixed.
Lost focus.looks 3d. red double. cant focus on red convergence.
This is a very common failure on Projection TV2_bing.gif sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing or you can call in a pro.
If you want to do the repair yourself check the site www.TvRepairKits.com.
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
724bcba.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant,step by step instructions, etc.
Cloudy picture on rear projection tv
Your picture guns and mirror is dusty. You can try cleaning yourself if you know what your doing, but I would let a qualify tech to do it.
Getting a double screen on the top left and lower right sides of the screen with a red tint to it
Here are some of the most common symptoms and examples of a convergence problem.
This is a very common failure on Projection TV2.gif sets.
  • Screen looks 3D
47a7bc4.pngSOLUTION
Their kits include a step by step instruction guide, original OEM Sanyo2.gif STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
3answers
I have a glow or a shadow around everything I watch...I tried the converse blue but i dont know if i did it right bc it didnt work...how can I fix that?
CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
1helpful
2answers
Couldy image
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here are some photos of convergence problems.
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
2answers
Cloudy LCD
I think camera screen (LCD) is broken thats why you getting image as cloudy.
1helpful
Cloudy patches from backlight leakage in LCD TV
You have to send it back to company to fix this problem>
Sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
