Hi,, Its a bit difficult to tell why this is happening as I will need a bit more information to help you fully resolve it. But generally the printer status Is if the printer is Online or Offline. this issue is mostly caused by driver failure..
try this fix it should resolve 80% of the issues that cause this.
1.) unplug the USB cable from your printer to the computer.
2.) Right click on the printer in devices and printers (exact spot where you were showing the printer in the vid) and click remove device.
3.) make sure the printer is powered off
4.) plug in the usb cable back into the printer and another usb port of the computer.
5.) turn the printer on.
windows should detect and reinstall a new driver for that printer.
it should work now. If not let me know and we'll go through a few steps to determine whats happening.
SOURCE: can't get computer and printer to communicate
Make sure the wireless LAN of your computer is set to AdHoc mode if the Printer is set to that function.
SOURCE: hi i have a kodak ESP 5 printer and having a
try and reseat the print head twice........to check how to take out and put in print head you may visit www.kodak.com/go/printheadsupport . If you still get that same error then its for print head failure and just need to contact Kodak.........
SOURCE: Kodak ESP 3 printer does not print YELLOW
no,kodak replace printheads free of cost, and if they send a printhead and that doesnt solve issue and in next 30 days,u have same issue,then kodak sends a replacement printer. and esp-3 printers are considered o be in warranty tilll now even if they are 24 months old. kodak is the best.. ur issue will be resolved.dont worry
SOURCE: Where can I buy print head for Kodak ESP 9
Kodak says that they will not let the print heads be sold at retail... I don't know why, the ESP series printers seem to all need their heads replaced regularly.
SOURCE: My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
