Icemaker not making ice, and no water in icemaker or filter
SOURCE: icemake not making water
At bottom hinge of freezer is the water line to door. Undo connection in line. It may be a quick connect. To undo push in on one end flange to release, and pull out line. Put bowl under end from under refrigerator and make sure doors are closed. Now push water dispenser and see if water comes out line. If it does, the line is frozen in the door. They had some models that had air leaks in freezer door. This causes insulation to freeze and water line freezes. Push in on inside of freezer door and see if it sounds like snow crunching. If it does it's probably frozen. Also peel door seal back a bit and see if is held on by numerous screws. If it is, it may be one of them that freezes. Call GE. They may still have the program going where you get 2 new doors free. Give them your model and serial numbers.
SOURCE: ice maker not working
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
SOURCE: Ice maker stopped working
Just a question... Is the motor that flips the ice down into its tube moving? or spining? your motor in the ice maker may have went out. might have to replace it.... hope this helps....
SOURCE: ge monogram zd115c automatic icemaker not making ice
Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
Dan
SOURCE: GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
