Language set-up mode
In order to enter the language set-up mode proceed
as follows:
1) Make sure the audio unit is switched off.
2) Press and hold buttons 1 and 4 simultaneously.
3) Press the power button and the radio will switch on.
4) Release all the buttons and the display will show
LANGUAGE.
5) Press the << or >> button and the language
setting display will change as follows:
ENGLISH ? FRENCH ? GERMAN ? ITALIAN
?DUTCH?SPANISH?POLISH?ENGLISH
Once the language has been set, switch off and
switch on again the audio unit by pressing the power
button.
Hi! Please try doing the steps below: 1.Open Control Panel and double click on the Regional and Language Options icon. 2.In the first tab, Regional Options,
select English (US), English (UK), or any other English (there are many
versions of English pre-loaded) as per your wish. The option is
available in the first drop down list under Standards and Formats. You may also click the Customize button next to the drop down to customize the format of date, time, currency etc. 3.Click on the next tab, Languages and then click the button labeled Details. In the Text Services and Input Languages dialog box, you can see all the installed languages. Select English in the list of available languages under Default Language Settings. 4.To create a keyboard shortcut for switching among installed languages, use the Key Settings under Preferences. Please note that you can also use the Language bar to switch among languages. Click OKto close the dialog box. 5.To set English as the default language for the particular user account, click on the Advanced tab of Regional and Language Options dialog box. Make sure English is being displayed in the drop down box and check the last option in the dialog box. 6.Click OK to close the dialog box and log off for the settings to take effect.
Hope this helps. Thanks for reading my suggestion.
All nuvis should have a full language database, so to switch from your current language to English all you would have to do is go. Tools > System > Language > Change all options to "American English" or " English". This is the same process for switching back to your old language and choosing a new one.
The following steps explain how to change computer language to English in Windows XP. 1.Open Control Panel and double click on the Regional and Language Options icon. 2.In the first tab, Regional Options, select English (US), English (UK), or any other English (there are many versions of English pre-loaded) as per your wish. The option is available in the first drop down list under Standards and Formats (see Fig 1). You may also click the Customize button next to the drop down to customize the format of date, time, currency etc. 3.Click on the next tab, Languages and then click the button labeled Details. In the Text Services and Input Languages dialog box, you can see all the installed languages. Select English in the list of available languages under Default Language Settings (Fig 2). 4.To create a keyboard shortcut for switching among installed languages, use the Key Settings under Preferences (Fig 3). Please note that you can also use the Language bar to switch among languages. Click OKto close the dialog box. 5.To set English as the default language for the particular user account, click on the Advanced tab of Regional and Language Options dialog box. Make sure English is being displayed in the drop down box and check the last option in the dialog box (See Fig 4). 6.Click OK to close the dialog box and logoff for the settings to take effect.
Changing Computer Language to English in Windows XP
If
you bought your computer with Windows XP in some other language set as
default, you need not worry. You can always change it using the Control
Panel. English, along with several widely used languages, is present in
almost all Windows XP installations. You only need to set it up so that
your copy of Windows XP works with English. The following steps explain how to change computer language to English in Windows XP. 1.Open Control Panel and double click on the Regional and Language Options icon. 2.In the first tab, Regional Options,
available in the first drop down list under Standards and Formats (see Fig 1). You may also click the Customize button next to the drop down to customize the format of date, time, currency etc. 3.Click on the next tab, Languages and then click the button labeled Details. In the Text Services and Input Languages dialog box, you can see all the installed languages. Select English in the list of available languages under Default Language Settings (Fig 2). 4.To create a keyboard shortcut for switching among installed languages, use the Key Settings under Preferences (Fig 3). Please note that you can also use the Language bar to switch among languages. Click OKto close the dialog box. 5.To set English as the default language for the particular user account, click on the Advanced tab of Regional and Language Options dialog box. Make sure English is being displayed in the drop down box and check the last option in the dialog box (See Fig 4). 6.Click OK to close the dialog box and logoff for the settings to take effect. Though
this is the most common method used to change the computer language to
English in Windows XP, it only changes the GUI and sometimes creates
problems with few applications such as Internet Explorer and Outlook
Express. If you are facing such problems, you can download MUI patches from MS download center. NOTE: The above method is often considered as a temporary solution when you have to use different languages. To change the computer language to English in Windows XP so that it has a system wide affect,it
is recommended that you perform a fresh install of Windows XP and
select English when prompted for language during installation. Later, you may install other languages as required.
Image References Read more: http://www.brighthub.com/computing/windows-platform/articles/46362.aspx#ixzz1BFXeeYOl
The default control panel display language is set for English.
Supported languages are: English, French, German, Italian,
Spanish, Finnish, Danish, Dutch, Swedish, Norwegian, Turkish,
Polish, and Portuguese. Follow these instructions to change the
display language.
1 Switch OFF the printer.
2 Press and hold Select while switching the printer ON until
SELECT LANGUAGE appears in the display.
3 After the power-on self test, LANG=ENGLISH appears. Press
[Value+/-] until the desired language appears in the display.
4 Press [Select] to save your choice. An asterisk (*)appears next
to the language to indicate it is now the default.
5 Press [Go]. The On Line indicator is lit, and display messages
are now in the language you selected.
switch on machine click start>setting >control pannal >clock language region > regional language option > after that select language english if its not changed then enter cd and reformatt it by selecting english language
