There could be a few possible reasons why your Scotch laminator has stopped heating up. Here are some things you can check:
- Power supply: Make sure that the power cord is securely plugged into the wall outlet and the laminator. If it is plugged into a power strip, try plugging it directly into the wall outlet to eliminate any potential issues with the power strip.
- Overheating protection: Many laminators have an automatic shut-off feature that kicks in when the machine gets too hot. Wait for the laminator to cool down and try turning it on again.
- Thermal fuse: The laminator may have a thermal fuse that has blown due to overheating. This fuse is designed to cut off the power to the heating element if the temperature exceeds a certain level. If this is the case, you will need to replace the fuse.
- Heating element: The heating element itself may have failed. This is less likely than the other possibilities, but it is still a potential issue. If this is the case, you will need to replace the heating element.
If you have tried the above steps and are still having issues with your laminator, it may be best to contact the manufacturer or a professional repair service for further assistance
I have been using the laminator for about 3 years. I had a piece of lamination that got stuck in the machine. I removed it and ever since it will not heat up.
