Re: Does the GBC Ultima 65 have an adjustable pot to...
Yes, your can adjust the heat, depending on if your machine id a straight Ultima 65 or a Ultima 65-1. The pot is on the main board.
the Ultima 65-1 only has 1 pot. 405-324-6092 Westco Laminating Service
Check the orange rollers for damage. If they aren't smooth all the way around then that could be causing your problem. If the air gaps are on edges of the laminate, a tension adjustment or film could be the problem as well.
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
either the top heater tube, (inside the orange/red roller) is burned out (Open) or the wire on either side of the heater tube is burned or broken in half. It\'s not as bad as you might think.
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
By "upper tension" do you mean the hex screw located inside the left panel? If you tighten this until there is no space between the heat rollers it should eleminate the problem. If it is continues to loosen, back the screw out, apply a small amount of locktight to the threads before replacing the screw.You can find locktight at any hardware store usually in the Paint section near the glues. Hope this helps. Good luck
