20 Most Recent Gbc HeatSeal Ultima 65 Laminating System Questions & Answers
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Gbc HeatSeal... | Answered on Oct 03, 2018
So this is how you remove the fuse that's underneath the machine, under the power button? Thanks!!
Gbc HeatSeal... | Answered on Sep 30, 2017
This is just rediculous. Where's the friggin answer?
Mine won't even come on. JUNK!
You may have the film tension set too tight or a pulley has come loose from the drive train. The drive train is behind the right cover.
first, remove both rollers with the film on them, then I usually cut the film between the red/orange rollers and the rear gray rollers, this allows you to run the laminator in either forward or reverse to unwrap the laminator, there is not exact science here, just use common sense and don't use anything sharp up against the rollers. West Laminating Svcs 405-324-6092
Gbc HeatSeal... | Answered on Jul 11, 2016
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Gbc HeatSeal... | Answered on Oct 02, 2015
Your key panel membrane is going bad, very simple to replace.
Westco Laminating Svcs, 405-324-6092
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
The Circuit breaker is located on the underside of the machine near where the electrical cord goes into the laminator. West Laminating Svcs 405-324-6092
Could have a bad heat lamp, do your adhesive feel tacky on any of the rollers? Are you may have a bad triac
DO YOU HAVE THE DULL SIDE MEETING TOGETHER AND GOING THRU THE MACHINE
most likely, someone has unscrewed the thumbscrews in the right side "collar". Best thing you can do is loosen both thumbscrews on the both collars, push the film on the shaft as far left as you can. then tighten both screws back down as tight as you can by hand. then grab the film and push the entire assembly to the right as it's spring loaded to the right. once it clears the keyed shaft holder on the left, just lift up and out. the right side collar screw should never be loosed. it just causes problems. West Laminating Svcs. 405-324-6092
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Gbc HeatSeal Ultima 65 Laminating System Logo
128 questions posted
Top Gbc Office Equipment & Supplies Experts
ADMIN Canada
ADMIN Canada
ray gallant
Kenneth Simmons
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Gbc Office Equipment & Supplies
Most Popular Question
when pushing run button tends go in
  • Office Equipment & Supplies
