Its a DLP, when was the lamp replaced last---I am not saying it is the lamp but want to know when last replaced and if with a Hitachi lamp.
I replaced the lamp assembly about 6 months ago. Purchased from Laptop or less it was the same part number. But I experience problems with the part because it had a manufactures flaw with the guide holes in the wrong position. So they finally sent me a suitable replacement. Originally replaced because the picture was to dark during the day and the new lamp gave a brighter picture for about 4 months. It works fine but the picture is hard to view unless the room is kept dark. I'm going to remove the back and check the fans and capacitors.
I bet they got a correct housing and put a generic bulb in it--lamp is critical and I doubt it is a fan or cap issue, good luck and I hope you find it.
I reinstalled an old lamp I keep for back up and it worked fine all day. So it looks like you were right about the lamp I was using. I was wrong about the time I installed the lamp, it was 7/27/12. I will make sure to purchase the orginal lamp. Thanks.
SOURCE: Hitachi projection 57 inch tv screen just went black, but still have sound
Research at www.HitachiServiceUSA.com ........T.
SOURCE: 53FDX01B Picture went black
is the screen lit up?
If so the video module is bad.
replace the surface mount caps app. 8 to 10
or replace module
guy9
SOURCE: Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
