vertical lines about 1/8 in width space about 1 inch apart across screen. This is for a 42 in...
(More)
vertical lines about 1/8 in width space about 1 inch apart across screen. This is for a 42 in philips plasma tv model 42PF5321D/37. Thanks
i have a philips 42pf7320a/37 that when i turn the tv on the picture is a red shade and some of the...
(More)
i have a philips 42pf7320a/37 that when i turn the tv on the picture is a red shade and some of the pixels are black. The light on the bottom of the tv is green though.
my tv is on the wall and i have recently bought a dvd player, which has scart leads, on my tv i only...
(More)
my tv is on the wall and i have recently bought a dvd player, which has scart leads, on my tv i only see a hdmi cable on the side wgich is not the same connection as the scart leads, does the amber light tv have a scart connection on it
black screen red light flashing, i unplugged the tv for 10 minutes when i plugged it back in the...
(More)
black screen red light flashing, i unplugged the tv for 10 minutes when i plugged it back in the same problem black screen red light flashing
42 phillips lcd losses picture after warm up about 1hour picture becomes scrambled. can this be...
(More)
42 phillips lcd losses picture after warm up about 1hour picture becomes scrambled. can this be repaired easily
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
Anyone with AKAI problems can download their service manuals at http://esi.fox-international.com. Just select the product type and a list will...
written by Kongsberger
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
