SOURCE: Need Boost SIM card to work in Nextel Motorola Buzz+ ic602 phone.
I called Boost support about the same issue and I was told that that particular phone and any other Ic series phone by motorola will not work with Boost Mobile. There was also a few other phones that will not work. Try calling thier support line and requesting the list of phones that won't work. Good luck.
SOURCE: have Motorola F3 850 i put sim card in it it says no sim card
it could be that the sim card has damage to the underside connectors. try wiping these down very gently and place the sim as carefully as you can then try again.
SOURCE: transfer contacts from a sim card onto cell phone
Go to contact list and select the contact.press option button then press copy option then press copy to phone.
SOURCE: Location of SIM card in Motorola Razr
Are you guys serious....
Verizon & Alltel (which happened to recently finalize the merge) use CDMA. CDMA does not use SIM cards.
AT&T, T-Mobile, etc. use SIM cards - wheter they are 3G networks, TDMA, etc.
SOURCE: motorola problem
I think u First contact Ur Service Provider..Otherwise u can Unlock the Sim From the Network.Change the Service..You can use the site http://www.mobileunlockguide.com/ For the Mobile Unlocking Instructions
