SOURCE: code for ferguson tv
These are all codes used by Fergies, hope one works for you.
0073 0287 0192 0190 0335 0238 0193 0109 0625
SOURCE: new problem with tv and Sony RMT-V202 Remote Control
The code for AVOL or type in AVL for a search it shows up as an APEX brand. Need to use the Apex code. 0156, 0748, 0765 0767, 0879. 0748 worked for me
SOURCE: need remote control code for a Sony Dvd RMT-D175A
www.remotecodelist.com ............................................T.
SOURCE: how to program remote model # RMT-D130A
Found the manual online, here it is:
http://akamaipix.crutchfield.com/Manuals/158/158DVPN600.PDF
Go to page 60. Basically, just hold the TV Power button down, hit your manufacturer's 2-digit code, and release power button. If the code is right, the TV will power off and then back on again. The manual only shows numbers 01-19 in use, so I guess you only have to trial-and-error a max of 19 codes (which is ultimately faster than downloading and opening the manual)! I hope this helps you out.
SOURCE: Need help on using a sony RMT-833 remote control unit
The Sony RMT-833 remote is for a Sony Camcorder - see http://www.replacementremotes.com/store/images/RMT833.jpg
I think you mean the RM 833 remote - if so try eBay as listings there suggest it works with Number: RM-833 Compatible with TV Models: KVX250,
KVX2501D
Hope this helps
