How to empty waste toner box
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
SOURCE: My Magicolor 2300dl printer displays
. Remove Waste Box, Empty box, wipe down w/ dry paper towel
. Turn machine off,. Unplug power cord
. there is a blue rectangular pull knob
.above Rectangular knob @an angle R 2 notches (contain ensors)
. Take an AIR can & hold 6-8 inches & spray N2 ea. sensor
. this should clear any particles that generate a false " Full " Signal
. credit to Nightangel for getting the ball rolling. Thx
SOURCE: Waste toner near full?
You can empty the waste chamber on the image unit by removing the screw from both ends of the unit, pull the ends off and empty it out. It's a messy job so have a good plastic bag and a toner vacuum if possible. The message might stay on awhile but will disappear with time. The alternative is a new image unit.$$$$$$
SOURCE: My kyocera copystar CS-1815 shows in the message
Hi there just open it up and inside there will be a small plass bottle that hold the waste toner you can clean out and put back.
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
