Question about Sony KDS-R60XBR1 60" Projection HDTV
Fuse replacement for KDS-R60XBR1 - Sony KDS-R60XBR1 60" Projection HDTV
    Top Expert:
  • Sony Master
  • 14,553 Answers
The info does not tell what is wrong---set has more than one fuse and if dead the set may still have lights on the front that light or blink (red one) in a specific sequence--5 blinks, pause and 5 blink etc.
A bit more info is needed to assist you.
Posted on Nov 08, 2012
davebies
  • 43 Answers
SOURCE: Resetting lamp hours
You will need to enter the service menu to do this. However if you were to push the wrong button on the remote you could really mess up the tv. So I suggest you call Sony and see if you can get an ASC to do it for you for a minor charge. There are literally hundreds of electrical adjustments in this service menu. I would adcise an asc do this for you.
Posted on Jan 23, 2008
welcomejee
  • 10594 Answers
SOURCE: Yellow Tint on Lower Right Side of Sony KDS-R60XBR1 TV Screen
Hi, Sony will repair your TV free of cost for yellow tint problem. Click Sony Support for details.
Posted on Jan 05, 2009
waynejamescm
  • 67 Answers
SOURCE: Yellow Tint in Lower Right Corner of Sony KDS-R60XBR1 TV Screen
What you probably have is a very well known problem with the optical block. As it covers the screen, it will turn everything else greenish/yellow.
The optical block is very commonly replaced and an expensive repair, but the extended warranty (in place for all these TV's regardless of purchase date) on these sets is expired or about to expire. I would urge you to call Sony (1.800.222.SONY) immediately to try to get assistance, and to see if the warranty is up on it.
Hope this helps you...
welcomejee
  • 10594 Answers
SOURCE: replacing the exhaust fan on a KDS-R60XBR1
4 times blink shows problem of fans not running or connector of fan is not attached properly.
Please recheck the things what you removed during fan replacement and make sure all that is mounted and connected securely.
Posted on Feb 13, 2009
SOURCE: KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Posted on Mar 31, 2009
Sony KDS-R60XBR1 No picture
Sounds like your light engine might have broken. Its around a $400 fix and I noticed Tri-State is having a sell on there about 341 its easy to replace it here is the link
http://www.tristatemodule.com/casearch.aspx?SearchTerm=kds-r60xbr1&asug=&view=grid&lang=en
May 14, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Tv not bright enough on a sony kds-r60xbr1
When was the lamp this model uses for brightness last replaced? These as a rule have a 2,000 hour or 2 year average lifespan and many just before they fail will go darker, picture will come up slower and be a bit dim.
Dec 07, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
Sony sxrd kds-r60xbr1 flashing red light all the time
Are you sure the lamp is pushed in far enough and did you make sure you screwed cover back on tightly?
Mar 13, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
My sony sxrd made a small pop sound and now there is no picture and only a static kind of sound. could it be a fuse? or is it something else?
It is very possible that the sound you heard was the lamo, the static sound is the ballast trying to light the lamp, replace the lamp and you should be fine.
Aug 11, 2010 | Sony XL-5100 Projector Lamp for Grand WEGA...
My KDS-R60XBR1 has a total green screen, what options do I have?
Replace Light Engine or Buy New TV .Call Encompass Parts 1-800-638-3328
Nov 30, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60XBR1 bLINKS 6 TIMES
When I try to look up blink codes I'm getting conflicting info. On this model is the lamp on side of TV? If so 6 blinks is showing as lamp door error, the micro switch the lamp door makes contact with is either not closed all the way or possibly defective.You can try reseating door or check the switch and wiring connections coming off it. You could try temporarily by-passing the switch by making your own short across the plug it connects to.
If the lamp mounts in front 6 blinks is a defective thermal fuse.The fuse is mounted right next to the lamp.From the back you can disconnect the plug for the fuse and check for continuity if its open its bad.
Apr 30, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Jan 05, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60XBR1 60" Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
