Question about Sony KDS-R60XBR1 60" Projection HDTV
KDS R60XBR1 Red Light blinks 3 times when turning
Sony KDS R60XBR1 Red Light blinks 3 times when turning on.
Posted by orrisk on
  • Anonymous Mar 13, 2014
    sony KDS-R60XBR1 pop then red light flash 3 or 4 times
  • Anonymous Mar 26, 2014
    need to find out what the meaning of red light blinking 3 times means when installing replacement bulb
bsandy5550
    Welcome Back:
    Visited the website for 2 consecutive days.
On my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Posted on Mar 31, 2009
Sony KDS-R60XBR1 No picture
Sounds like your light engine might have broken. Its around a $400 fix and I noticed Tri-State is having a sell on there about 341 its easy to replace it here is the link
http://www.tristatemodule.com/casearch.aspx?SearchTerm=kds-r60xbr1&asug=&view=grid&lang=en
May 14, 2013 | Sony KDS-R60XBR1 60" Projection HDTV
Fuse replacement for KDS-R60XBR1
The info does not tell what is wrong---set has more than one fuse and if dead the set may still have lights on the front that light or blink (red one) in a specific sequence--5 blinks, pause and 5 blink etc.
A bit more info is needed to assist you.
Nov 08, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
Red standby blinkig light 4 time on a sony 60 in wega
4 Blink 9 out of 10 times is your lamp fan. Check and make sure it clean and free of debrey. Spin it and see if there is any grinding noise. If after you clean and reassemble and the set still shuts down, either replace the lamp fan or check your outher 3 fans as well.
Apr 26, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
Sony sxrd kds-r60xbr1 flashing red light all the time
Are you sure the lamp is pushed in far enough and did you make sure you screwed cover back on tightly?
Mar 13, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
Sony tv red light blink 4 times on 60" WEGA
When your red light blinks four times on the Sony KDS-R60XBR1 60 inch HDTV, this is an error code for a stopped up fan. You will need to check the ASU board to verify Fan1-4 power to the fan is supplied, next check the fan connector to make sure it is properly connected, and finally make sure the fan is not caught in the wires or harness.
Feb 27, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Red light blinking 5 times. is a fan problem on a sony KDS-R60XBR1
here are the fans you need are you sure this is the problem
http://www.discount-merchant.com/SONY-Cooling-Fan-Set-Cooling-Fan-Set-p/1158984.htm
Sep 15, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
I'm getting the 4 red light blink on my sony R60XBR1. What should I do. I've read to just clean the fan. Is this legit?
Yes this is legit. There's 2 fans and take out the big fan and clean it using a brush or something. I just did yesterday when my TV would not turn on with 4 red blinking light. Now the TV is working like new. Make sure you put everything back including the casing before you turn on the TV.
May 09, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Replacing the exhaust fan on a KDS-R60XBR1
4 times blink shows problem of fans not running or connector of fan is not attached properly.
Please recheck the things what you removed during fan replacement and make sure all that is mounted and connected securely.
Feb 13, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KDS-R60XBR1 60" Projection HDTV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
